My laptop is not starting charging
@mobilezone8947 start off with the simple things. First you want to check your power supply. Make sure it has the proper voltages. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. After that you need to check and see if your motherboard even gets power. For that of course, you need to open it up. This teardown Packard Bell EasyNote TK87-JO-050PL Teardown can help you with this. Post Some good pictures of what you see. That way we can see what you see iFixitでの質問に画像を追加する方法
You should also consider replacing the battery. A depleted battery can no longer be charged.
ガイド
難易度:
とても簡単
2 - 5 minutes
ガイド
難易度:
中レベル
10 minutes
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 30
今までの合計 73
