メインコンテンツにスキップ
2020年3月に発売された、iPad Pro 12.9インチ第4世代の修理と解体情報。モデル番号はA2229。
This board is toast right?
So I have a customer who brought me an iPad Pro and it's literally stuck on the apple logo. No Boot looping, just solid logo for eternity. It will boot into DFU mode, but not Recovery Mode and when it does, it's not recognized by Mac or PC.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Have you opened up the device? I know with iPads, that is easier said than done but in this case may give you a better idea. Stuck on Apple logo usually has something to do with the OS. Or as Dan mentioned, it could absolutely be the NAND storage.
That being said, "it's not a board problem until you're sure it's not a parts problem." I would want to at least look at the device's internals. This also smacks of potential liquid damage to me. Which will be much easier to spot if you look at the inside. But I also realize that's a lot of work for what may end up being. "Welp. The board is fried,"
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
This sounds like the flash has failed. Replacing the chips is not trivial but could be a win if the storage was on the lean side which can explain why the chips died from excessive over-writing.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
rickcostel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 199
