The Nokia C5-03 is a budget touchscreen smartphone, first released in December 2010.
Alok Gaur @alokgaur
評価: 1
投稿日: 2012年2月23日
How can I find out the RF antenna port location inside the phone. I want to connect an external wired RF cable to that port for some testing purpose.
この質問は役に立ちましたか?
Thanks for your response.
Yes, I would like to use antenna module located on the phone, but how can I find it. Where is the antenna module in this picture?
Alok Gaur さんによる2012年2月28日
Pull your module and use the copper contacts where the module connects to the logic board
oldturkey03 さんによる2012年2月28日
Yes, I have taken out the module. But I see two RF ports on the PCB. In the Phone schematic these are numbered as X7001 and x7002. How to figureout whichone I should use to solder an external RF cable.
oldturkey03 @oldturkey03
評価: 812.3千
1.2千
920
2.4千
Alok Gaur, may be this will show what you are after. Otherwise, have you consider using the antenna module as a tracing point.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,713
3 件のコメント
Alok Gaur さんによる
oldturkey03 さんによる
Alok Gaur さんによる
