メインコンテンツにスキップ
2022年2月25日に発売されたValve製の携帯ゲーム機「Steam Deck」の修理・分解・トラブルシューティング情報です。型番1010で識別されます。
209回答 すべてを表示
Where can I find parts not on iFixit?
I was doing a full case swap and accidentally broke part MEOJ24900KDL. It's the long ribbon cable that goes along the top vent. I've tried looking in few places but can't seem to track anywhere down to get a replacement. I also suspect I broke the ribbon cable from the display to the motherboard, but I might just buy the upgrade screen anyways, will see. Anyways, whatever help would be much appreciated!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
16 件のコメント
please check that part number
さんによる
@mayer I did check it again and got the same number of the barcode. However I was using Google lens which might be the problem. Im going to try a different barcode reader but for now I just uploaded the pictures if the part and barcode.
Edit:
I tried 2 more qr readers and got the same part number off of both.
さんによる
@drevis25 what else does it say on the ribbon cable? To the left of the FPC....
さんによる
@oldturkey03 Three things, 2248 TSF (in small print) F7A_MIC_FPC, in that order.
さんによる
@drevis25 looks like the Mic Flex. Now just to find it......
さんによる
11件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Hey guys I wanted to let you know I bought my replacement from for this eBay seller:
https://www.ebay.com/itm/115989144859?mk...
Mine hasn't arrived yet but I"LL keep you updated once is been installed
(REED DESCRIPTION TO WHICH DEVICES ARE COMPATIBLE WITH !)
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Looks legit!!! You are my hero!!! I'll wait for an update before by but again it looks promising.
さんによる
As soon I get it installed and tested I'll let you know 😉👍
さんによる
コメントを追加
@drevis25 given its a new device, I'd contact Steam and see if they'll let you purchase new parts directly. It may be a while before used parts start showing up on eBay, that usually only happens once warranties start running out.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Drevis さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 97
今までの合計 266
