メインコンテンツにスキップ
モデル番号はA1708/EMC 3164。2017年6月発売。このエントリーレベルのMacBook Proには伝統的なFunction Keyが搭載されています(OLED Touch Barの反対)。
567回答 すべてを表示
How hard is it to replace Keyboard on MacBook Pro 13" Retina (Fn keys)
My "MacBook Pro 13" Retina (Function Keys, Late 2016-2017)" is missing two keys and others are super loose. Looks like the keyboard is about $99, which is great, but I want to know how hard it is to change? I have done many easy and moderate ifixit repairs, so I was curious. Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Have a look at this Macbook Pro 13" Retina keyboard replacement - YouTube but I would try and replace the keys that are missing
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
FYI - The video is for the older 2015 and older Retina systems. Please refer to the iFixit guides on how to disassemble the system. As there are quite a few differences.
さんによる
コメントを追加
While it is possible it’s not something I recommend for a first timer. This is a very nasty job as you need to be fairly physical yanking the old keyboard out and not damage other things in the process. Then you need to get all of the plastic rivets out and the replacement keyboard better come with the needed screws and do make sure you get the same exact keyboard as the ISO case is different than the NA/US case.
If the keyboard is too badly damaged and that is the only option I would recommend replacing the full uppercase assembly. While expensive it will get you to a better place MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Upper Case also note you likely need a new battery anyways given the age of the system. So plan for that as well, as transferring the old battery really doesn’t make much sense as it likely will be damaged just in the process of removal MacBook Pro 13インチ Function Keys 2017 バッテリーの交換
Here’s one source for the KeyCaps if that’s all you need 2016/17 MacBook Pro KeyCaps click on the image to drill down.
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Upper Caseの画像
製品
$169.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
erik さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 24
今までの合計 82
