I have a problem with the TouchPad
Hi, I’m Vivek Chaudhary from Rewari
I have a 15” MacBook Air with problems with TouchPad
This system should still be covered under Apple warranty as it was just released. Are you sure you picked the correct system? To be sure plug in your systems S/N here EveryMac - Lookup see what it tells you, the newer models won’t report correctly, even still let us know.
As to your problem, did you have a liquid spill (or get it wet) or damage the system in someway?
このアンサーは役に立ちましたか?
you should get the trackpad replaced i believe,thats what it is most likely like 99% chance that its that
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 121
