メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Onkyo TX-800は1989年に発売され、2002年に生産終了したソリッドステートレシーバーです。
Why won't the left main speakers work?
I bought new speakers for my Onkyo receiver. I've connected the speakers with speaker wire to the main speakers outlet in the back of the receiver. Only the right side speakers produce sound. To check if I'd made a faulty connection, I then switched each around, and the same result occurred; the right side works, the left does not.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
3 件のコメント
Laura, don't mean to insult you, but did you check the balance settings? Any difference?
さんによる
Yes, I'd already looked into the balance settings.
Looking at the manual, t appears as though this is over-my-head. I will look into finding professional repair. Thank you!
さんによる
Laura, thank you for accepting my answer. Best of luck to you....:)
さんによる
コメントを追加
1 件の回答
ベストアンサー
if you have no difference on your balance settings, I would go ahead and take a look at the AN7470 Stereo decoder as well as the IC NJM45580-x. Of course you also should look for any burned out components on the logic board. Download the service manual for your Onkyo from here. It does have the circuit diagram as well as a parts list that will help you with it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Laura さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 16
今までの合計 4,088
