メインコンテンツにスキップ
MacBook Pro 16インチの解体情報と修理ガイドです。2019年11月に発売されました。モデル番号はA2141とEMC3347です。
213回答 すべてを表示
Won’t turn on. But gets warm even in dead state
Two days back I was using it. Must have shut the led instead of turning on. Two days after I open the led, nothing happens, so I put it to charging. No response to power click after charging.
Tried these things
  • 10 second power button press
  • Smc reset
  • Authorised service center tried nvram reset too I think
  • Os restore with Apple configurator
Current status
  • No fan sound
  • No response from any visual indication
  • Haptic feedback experienced from touchpad
  • Laptop gets warmed when put in closed space like bag. Goes down once kept in open space, i think somethings getting a bit hot and machine’s fan are trying to get rid of the heat. No fan sound though
  • Apple configurator recognizes the machine but no luck in restoring it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The charging logic will continue to charge your battery and as the battery ages it can’t accept the power offered, so it gives off heat. I’m sure you’ve encountered an extension cord or even a room heater cord or plug getting warm. That’s the same effect.
I’m guessing here that your battery bad. But to verify you’ll need to open the system to inspect it for blistered cells.
このアンサーは役に立ちましたか?
スコア 1
13 件のコメント:
Thank you Dan for responding
So you suspect its a battery issue, thats why its not turning on or the reason why its getting warm even in dead state.
It’s absolutely unresponsive
さんによる
Hi @dan
We tried restoring/erasing the chip with apple configurator. That didn’t work either.
There is haptic feedback on touch pad, machine heats up after sometime.
Store executives have advised to get the logic board replaced.
What would you suggest to do?
さんによる
@mayurikulkarni - I think you need to locate someone with deeper skills who can fix your logic board if the issue is that. Apple made these new systems harder to diagnose as one can't easily connect a spare battery like we could before. Now you need to take it out to make room and in doing so you likely will hurt the battery as it doesn't like being stretched and twisted!
There are more advanced Independent shops which maybe your best hope to save some money as a new logic board is not cheap!
So where on this big Blue marble we call earth do you live? Country and nearest major city, lets see if we can aim you to someone.
さんによる
I do have some hope as Apple Configurator could detect the machine. I’m living in Mumbai, India. I would really appreciate some help locating someone skilled to do the operation
Thanks a ton in advance
さんによる
@mayurikulkarni - Are you planning on traveling to Europe or Australia? Sadly, I don’t know of any one in India!
さんによる
8件以上のコメントを表示
コメントを追加
回答を追加する
Mayuri Kulkarni さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 107
