メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
A mid-range smartphone from Samsung released in 2019.
Galaxy A50 wont boot completely, but keeps rebooting at Samsung Logo
Few days ago, my Galaxy A50 turned off while working, since then it is not booking completely. Instead, it keeps rebooting till Samsung Logo. No Water damage, No drop or accidental fall. Device also not entering in Hard re-set mode. It's OS was last updated in January 2023.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Can you force the device into recovery mode? You need to hold up and power simultaneously during the startup sequence. It may take a few tries to get the timing right if it is automatically rebooting and you don't get it right first try, don't give up immediately.
If you can get recovery mode launched, it will go into a menu with options such as those seen here:
(Image Credit HardReset.info)
While most of those options have nothing to do with bootlooping, wiping the cache may fix a software issue, and factory resetting will delete all your data but will almost guaranteed fix one (though, again, would delete all your data). Using the bootloader or applying update settings may also help if you can source the right files for your device.
That is all assuming it is some kind of software bug. If none of that works, it is likely a hardware issue, and there are many faulty parts that can cause bootlooping from the battery to the cameras, but the most likely is a motherboard issue which would need to either be replaced, or repaired by a dedicated board repair specialist.
Good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
@abhishek41760 you did not tell us if you ever replaced the battery. I would definitely start with that. A bad battery can cause a reboot.
Samsung Galaxy A50 Battery Replacement
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Abhishek さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 46
今までの合計 1,589
