Can't reset gfci
The built in gfci in the cord will not reset. How can I fix it?
@rickystuart I would check to see if there is actually something wrong with the cord which prevents a reset. If the cord is okay (for sure?) then you may have to replace the GFCI. The GFCI may have become faulty or it lacks a connection. If I remember right those use security screws which "prevent access". Replacements are available on select sites.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 336
