メインコンテンツにスキップ
Repair guides and support for your LG TV.
1350回答 すべてを表示
LG TV suddenly displays half black half rotating colours.
LG 65UB980T TV
Hi all, So a bit of background. I've had this tv for about 7 years now and a few months ago the image started ever so slightly shaking in some scenes (left to right) and now it has completely gone. When the tv turns on sometimes it is half black and half rotating colours like another post ive seen here however other times it is staticy. But in both cases it seems like its 2 separate halves on the tv. I've replaced the tcon board to no avail so am now suspecting maybe one of the cables? Thank you.
Update (07/11/23)
@oldturkey03 took a bit of unscrewing but here it is!
https://imgur.com/a/XN1ImQf
the pictures are left to right from top to bottom. unfortunately one screw stripped so i cant really see the top left board
Update (07/11/23)
@oldturkey03 might have found the culprit :(
https://imgur.com/a/OEm3r5Z
i tried disconnecting that portion of the screen however it just results in a weirder looking glitched screen
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
最も参考になった回答
@niloyshehrin that is a bad panel. The left side of the TV panel lost contact with the LCD driver boards. Take your TV back cover off and post a couple of picture of all the boards. Do not forget the "skinny boards" that connect to the panel via a row of ribbon cables. You can't remove those boards. That are the driver boards and that is where the error originates from. Let's see if we can find a bad connection or bad component.
このアンサーは役に立ちましたか?
スコア 2
13 件のコメント:
ahh thats unfortunate. im assuming if those are the bad parts then its a full panel replacement? ill send some pictures in the morning (maybe in around 10ish hours?). this is a picture of my t-con board https://imgur.com/a/ZAwgwNx , if i take out the cable circled (it is one of the 3 cables going to the motherboard, all of the ones on the right side go to the motherboard) then the screen goes into a test thing like this video: https://www.youtube.com/watch?v=HWugyoWq...
not sure if any of that is important haha
さんによる
@niloyshehrin there might a way to temporarily fix it with a Tape-Off but it's tricky and may not work. Let's see what those boards show. No worries about the time. We'll be around :-)
さんによる
@oldturkey03 had some time on my hands so i snapped some photos! https://imgur.com/a/fSs7Iwu
heres what i could find. im not sure where the driver boards are on this tv, is there more stuff i have to take off to find it?
さんによる
@niloyshehrin the ribbon cables from the T-con board usually terminates on those boards. Depending on your chassis those can be a hard to find, You'll have to getto the bottom/top end of the actual panel to see them.
さんによる
also there seems to be some rainbow coloured heat damage on the top right of the back cover so maybe thats indicating something
さんによる
8件以上のコメントを表示
コメントを追加
回答を追加する
Niloy Shehrin さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 34
今までの合計 343
