Pinout of the display connector.
@danj - By any chance do you have the pinout/values of the the display connections?
I'm doing a little bit of a mod.
The older Unibody systems use LVDS signaling which is dependent on a dual connection for the active line. Here’s a good write up Low-voltage differential signaling.
Without understanding what you are trying to do it would be hard to offer a signal breakdown as the way it works is a bit more complex.
このアンサーは役に立ちましたか?
@danj - I'm needing to check the wire pinout, to make sure that it's the right pinout for the new display. I'm testing an ai's guide it gave me
@beanman56 - “I'm testing an ai's guide it gave me” ??
@danj - Don't ask..
@beanman56 - I was expecting a typo😊
@danj - I'm testing chatGPTs guide knowledge.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 97
