メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1200回答 すべてを表示
Panic CPU x caller - rebooting every few seconds
I need some help. My iPhone restarts every few seconds when I unlock it. When it is locked it works all the time without rebooting.
I read the error code but I don't know what it means, can someone guide me where is the problem?
Panic code
{"bug_type":"210","timestamp":"2023-06-28 03:14:09.00 -0700","os_version":"iPhone OS 16.5 (20F66)","roots_installed":0,"incident_id":"D6DCF4B5-6A5E-446E-B318-FC8AB236FECB"}
  "build" : "iPhone OS 16.5 (20F66)",
  "product" : "iPhone10,3",
  "socId" : "8015",
  "socRevision" : "11",
  "incident" : "D6DCF4B5-6A5E-446E-B318-FC8AB236FECB",
  "crashReporterKey" : "c27374456cd62022bf606fff6bdb02803499bb8a",
  "kernel" : "Darwin Kernel Version 22.5.0: Mon Apr 24 21:10:12 PDT 2023; root:xnu-8796.122.4~1\/RELEASE_ARM64_T8015",
  "date" : "2023-06-28 03:14:09.29 -0700",
  "panicString" : "panic(cpu 2 caller 0xfffffff0105e0f54): AOP PANIC - No pulse on 0x109b248 - main(4) - \nuser handlers:\ntraceBuffer : \n280000008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140\nNo pulse on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
最も参考になった回答
We might need more of the panic, but in my recollection an “AOP No Pulse” panic often refers to the Taptic Engine (Vibration motor). That could also point to issues with the charge port since the Taptic Engine connects directly to the dock flex cable rather than the logic board. If you can upload a bit more of the panic it might help, there are sometimes some extra clues further in the text.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I added a link to the whole panic
but the vibration works normally after toggling the mute button on the side.
さんによる
Hi,
I am having the same issue on Iphone X with the same error code. Have you been able to fix it ?
さんによる
コメントを追加
Hi,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I do not remember exactly. but it was something with the ambient light sensor on the upper flex. Replacing the sensor flex with flood iluminator and proximity sensor fixed the error, but faceid needs to be programmed and repaired. In my case, the error occurred after flooding the phone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kamillski さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 20
過去 30 日: 108
今までの合計 958
