Are there any compatible iMac 27” 2011 graphic card
Hi all,
Im looking for some compatible graphic cards for a 2011 imac 27” that either has the apple firmware or do not require a flash in order to work
va
この質問は役に立ちましたか?
Hi all,
va
この質問は役に立ちましたか?
The iMac 27" (2011) model with EMC 2429 has a proprietary MXM graphics card format, which means that finding compatible graphics cards can be challenging. Apple used custom firmware on their MXM cards, which restricts the compatibility of third-party options. However, there are a few options you can explore:
Upgrading the graphics card in an iMac can be a complex task and may require technical expertise. Additionally, since the iMac 27" (2011) is an older model, the availability of compatible graphics cards may be limited.
I hope that's help
このアンサーは役に立ちましたか?
@redwave & @cedriccoco - Here’s a good source but it may take a bit of time before the higher end one comes available 2011 27” MXM GPU boards
過去 24時間: 4
過去 7 日: 14
過去 30 日: 47
今までの合計 497
