メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
m300としても知られるClipは、SanDiskが2007年に発売したシンプルなMP3プレーヤーです。
Why won't it charge
So I accidentally had it in the washer a while ago about a year I think. Itll turn on if I have it plugged in but once I take it off the charger even when it shows full charged battery it immediately turns off. I can use it as long as its plugged in.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
@hannaharellano this sounds like either a bad battery (don't always believe what the software tells you) or corrosion from the washer incident. I'd start off by replacing the battery.You selected the m300 Sansa Clip. Let us know if that is right.
The real issue here is that there are no guides, and no videos that I can find. There is a link to an archived webpage that will be of help to you. It can be done. You got this!
Here is the disassembled view and here is write-up of opening it
While you work on your Sansa, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hannah Arellano さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 38
今までの合計 604
