メインコンテンツにスキップ
The HP Laserjet Pro 200 Color MFP can be identified by its model number: CF145A. This wireless-enabled color multi-function printer provides ePrint, touchscreen access to apps, and versatile scan, fax, and copy options.
7回答 すべてを表示
Why are papers printing with "smudges" on both sides?
Every page is printing with "smudges" on both sides from top to bottom. While comparing multiple papers, I noticed the smudges appear to look the same and appear in the same location from paper to paper. So far, I've removed the cartridge tray and gently cleaned along the edges of the transfer bed. I have also inspected the toner cartridges and I noticed that some yellow (last/4th cartridge) is showing on the edges of the pink toner roller (3rd cartridge).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Laser printers use static to transfer the toner partials from the drum to the paper, this is done by applying a charge via a wire near the drum we call it a chromatron. This wire can get dirty effecting the effectiveness of the transfer causing the smudge effect.
You need to clean and the drum as some toner has built up on it along the edge.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks Dan! Unfortunately, I ultimately concluded that it was a bad fuser.
さんによる
コメントを追加
回答を追加する
Nick H さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 25
今までの合計 115
