メインコンテンツにスキップ
2020年3月に発売されたインテルプロセッサ搭載MacBook AirモデルA2179の2020年リフレッシュモデルの修理・分解情報です。
Having problems trying to rebuild my OS
build  Bridge OS 7.5 (20P5058),
@danj I’m having an issue with a 2020 MacBook Air
Its flashing the folder logo, internet recovery through WiFI gives error 2003f.
Trying to install the OS via USB it goes into the system and asks what I want to boot from but when I select the USB file it says security won’t let me boot from USB, change security by pressing command-r, when I do that it takes me to internet recovery again with no security option and the fan is running full speed when trying internet recovery.
Any ideas ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
The drive is encrypted so it won’t let you access it. You’ll need to visit an Apple Store for help.
このアンサーは役に立ちましたか?
スコア 0
16 件のコメント:
@danj i managed to get the os loaded via ethernet but now i sometimes get random restarts. there is a panic log but i cant make heads or tails of it
さんによる
@tech_ni - can you export it into a PDF and post it here so we can see it.
さんによる
@danj
panic(cpu 1 caller 0xfffffff020774a68): x86 CPU CATERR detected
Debugger message: panic
Memory ID: 0x6
OS release type: User
OS version: 20P5058
macOS version: 19H2
Kernel version: Darwin Kernel Version 22.5.0: Mon Apr 24 20:06:41 PDT 2023; root:xnu-8796.121.2~1/RELEASE_ARM64_T8010
KernelCache UUID: 898E82ABB7B6D9C47BA18414767F7655
Kernel UUID: A04DA547-BD69-39FF-A0E2-D59ED179A076
Boot session UUID: 75527CA8-CD8C-477F-BEAB-E36ED4BC714A
iBoot version: iBoot-8422.121.2
secure boot?: YES
roots installed: 0
x86 EFI Boot State: 0xd
x86 System State: 0x0
x86 Power State: 0x0
x86 Shutdown Cause: 0x3
x86 Previous Power Transitions: 0x70707060400
PCIeUp link state: 0x1614
macOS kernel slide: not available
Paniclog version: 14
さんによる
@tech_ni - Is that it?? This is way too small. The panic call memory state should follow this. I haven’t looked at Big Sur and newer back traces so things might have changed, besides this looks like this is a M series system not Intel is this the Late 2020 system by chance?
さんによる
@danj there is more to it but i cant add it, intel i3
さんによる
11件以上のコメントを表示
コメントを追加
回答を追加する
daniel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 232
