Why will my washer only spin on high
My washer only spins on extra high no matter what setting I put it on. Is this fixable?
Update (06/01/23)
The model number is 11047789701
Haven't come across this problem before in your model, but here's the tech sheet for the washer.
View and note down any stored error codes and then run the diagnostic test as described in section Starting Error History, Software Versions and Diagnostic Test: on p.8 and check what errors are displayed and if they're the same as was stored.
The error codes and their possible causes are shown on p.2 → p.8.
Let us know what you find
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 27
