メインコンテンツにスキップ
2019年8月に発表されたSamsungの第10世代フラグシップ”ファブレット”モデルです。トレードマークのSペンスタイラスが搭載されています。
touchscreen does not work
Touch screen comes on but doesnt register touch. Is there a way to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Has anything happened to the phone recently, such as a drop, liquid exposure, firmware update, etc.?
Your phone actually has two separate digitizers; one for your finger, and one for the S-Pen. If one fails, often the other will continue working; I had a Note 4 where the S-Pen digitizer failed but the touch screen still worked.
Anyway, assuming it's a hardware failure, the cause is almost always the digitizer rather than a problem with the motherboard. The fix is to replace the entire screen, as you can't really replace those three components separately, at least not without very specialized equipment and expertise.
So you'll want to try all the software fixes you can come up with first, such as hard resets, doing a backup and full restore, etc., to make sure it's a hardware problem. After that, you'll need to replace the screen. Here's the iFixit guide to doing that on your phone.
Samsung Galaxy Note10+ Screen Replacement - iFixit Repair Guide
Unfortunately, your phone is still fairly new and prices for a new screen haven't come down a lot, so it's going to be somewhat expensive to fix. You can buy a new screen right here on iFixit, and it appears to be available in other markets such as Amazon, eBay and AliExpress.
If you buy it from iFixit, I recommend the Fix Kit, as it comes with all of the tools and adhesives needed to do the job right for a minimal cost.
Good luck; let us know what you find!
Replace a cracked or malfunctioning AMOLED display and digitizer screen compatible with the Samsung Galaxy Note10+. Includes the front glass digitizer screen and 6.8 inch AMOLED 1440x3040 Display.の画像
製品
$299.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Devin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 283
