I want flash my Samsung
How can I flash my Samsung A70 phone
To flash your Samsung A70 phone, you will need to follow a specific process called "firmware flashing" using the appropriate firmware file. Here are the general steps to flash your Samsung A70:
Once your device reboots, it should have the new firmware installed. You can now set up your Samsung A70 and restore your data from the backup you created earlier. Remember to proceed with caution and follow the instructions carefully to avoid any issues during the flashing process.
このアンサーは役に立ちましたか?
note that you'll have to unlock the bootloader if you're not installing samsung software!
@ezzgen Not possible. Ever since Samsung got lazy and spun one permanently locked bootloader board for both locked and unlocked phones (thanks carriers) they are not unlockable anymore.
@nick You can unlock the bootloader on the galaxy a70, i've done it on my personal phone, although some carriers may have disabled this.
https://www.google.com/url?sa=t&rct=j&q=...
See above.
@ezzgen Only the ROW Exynos version. QCA US phones are permanently locked with a key unique to the phone Samsung does not give out or let you toggle to unlock.
@nick All versions of the A70 use the Snapdragon 675 SoC, my personal one was bought locally from a carrier in England.
過去 24時間: 1
過去 7 日: 7
過去 30 日: 34
今までの合計 316
