メインコンテンツにスキップ
モデル番号A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5もしくは3.8 GHz Core i5もしくは4.2 GHz Core i7 Kaby Lakeプロセッサ (ID iMac18,3) / Retina 5Kディスプレイ。システムは類似しているため、修理ガイドについては旧モデルのiMac Intel 27インチ Retina 5Kディスプレイ (Late 2014 & 2015) を参照してください。
294回答 すべてを表示
Fan speed too low after replacing it.
My fan stopped working, so I ordered one from ifixit. After replacing it, the fan speed idles around 450~490rpm, and won't go above 500 even when the CPU temp reaches above 90celsius. I've installed Macs Fan Control to try and manually adjust the fan speed to no avail. Is the fan I received from ifixit faulty, or is there something else I can try?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
This could be a faulty fan, but I would take a look at the Troubleshooting Problems After a Repair wiki page, just to cover all your bases. If the old fan wasn’t working at all, it could be the issue is still with something else, but I would make sure all the connections are sound. It could just be something as simple as it isn’t fully connected.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If forcing the fan doesn’t alter the speed, then the tachometer logic is not working properly. This tends to be a logic board issue. This will need reviewing of the schematics and board-view drawings measuring the voltages as well as inspecting the board for damage burnt components as well as corrosion damage.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hello Dan, thanks for your reply.
The day after I posted the initial question, the fan seemed to run at the normal speed (above 1200rpm), but since then it has returned to anywhere between 250~400rpm. I'm assuming it's probably a logic board issue as you've described.
I'm not really a tech person - I'm ok with disassembling and reassembling things, but not familiar with measuring voltages or swapping out chips, etc. Would you say my only option then would be to change the entire logic board?
Thank you in advance for your help!
さんによる
コメントを追加
回答を追加する
Kyu Hwang さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 34
