メインコンテンツにスキップ
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
561回答 すべてを表示
Is it safe to reapply thermal paste on 2012 mac?
My old device macbookpro retina 15 2012 A1398 is heating up easily since i didn't clean it and didn't reapply thermal paste.
I would love to reapply thermal paste/clean,but i just read that you need to remove old paste to apply new one. This makes me nervous,cause I’m not living in EU/US,so taking my device to off-brand Apple service centers will result in dead device in 9/10 cases. 11 years old thermal paste could become a rock and i don't think it's safe to remove rock from copper core(s).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I notice you've made a second post with a rephrased question. do you want this one to be the one you receive answers on or the other one as having 2 posts for the same issue can get confusing.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi @tkrzkr,
Thermal paste is basically infinitely replaceable :). This means you can remove it from your CPU and/or GPU and re-apply. Because this is a 2012 retina, i really hope your Dedicated GPU hasn't failed because it means your too late to applying thermal paste.
In order to apply it, just remove the remaining chunks on your processing unit using some alcohol or some other recommended method, and then purchase a tube of it (Noctua NT-H1 or Arctic MX-5 are some of the best ones) on somewhere like Amazon. After you've got your materials, apply a small amount of thermal paste on each processor. You can't apply too much, so make an educated guess for how much because you'll never have too much. If your not confident in yourself guessing, look up a guide online as Macbook pro re-paste guides aren't few and far between (AKA they are everywhere).
Hope this helps and let me know how it goes.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
TIM tends to be crumbly when it dries out. So it’s not like cement! Even still it often needs a bit of solvent to fully clean.
The heatsink it’s self is not the fragile part the silicon die (the black chip) is the more sensitive to damage.
Review this guide MacBook Pro 15インチ Retina Display Mid 2012 のロジックボードの交換 it will step you through the process. As far as the paste this guide offers how to effectively clean and apply a fresh coat MacBook Pro 15インチ Touch Bar 2017 放熱グリスの交換 the only thing you need to be careful is not over do the paste. Practice using some coins gaging how much paste is needed so you get the coverage but not squeezing out making a mess.
MacBook Pro 15" Retina Display Mid 2012 ロジックボードの画像
ガイド
難易度:
難しい
1 - 4 hours
MacBook Pro 15" Touch Bar 2017 放熱グリスの交換の画像
ガイド
難易度:
中レベル
45 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
tkr_zkr さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 21
今までの合計 171
