upgrade ssd from 64 gb to 128 gb
hi , i want to know if it is possible to upgrade de ssd unit in my MBA 11" , Model 1370 to a other with major capacity.
Thanks.
この質問は役に立ちましたか?
Thanks.
この質問は役に立ちましたか?
Check out some of the 3rd party memory houses for other options.
As an example Other World Computing:
http://eshop.macsales.com/shop/SSD/OWC/A...
Good Luck!
このアンサーは役に立ちましたか?
Hello Yuri,
I believe the Mid 2011 Macbook Air 11" can be upgraded to 256Gb SSD from Apple so you should have no trouble upgrading from 64Gb to 128 Gb.
Below is a link to the guide on how to remove/replace your SSD on your Macbook Air.
MacBook Air 11インチ Mid 2011 SSDの交換
Hope this helps,
Wes
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 626
1件のコメント
thank you, i think that i´m more sure of my doubt and i will buy a new ssd.
yuri さんによる
