メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
What is adhesive needed for the screen on iPhone?
Hello.
I'm looking for a new screen for my iPhone 4 including the glass and everything and I asked a seller on Ebay if it included everything and he said it didn't include any adhesive.
So the question is what is adhesive and what does it do? The seller didn't understand what I was asking about.
Would someone please explain to me what it does and why it's important to have? :)
Thanks in advance, Gronko
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
if you are only buying the front touch screen, called the digitiser, without the LCD (picture screen/display) attached then you will need to also buy an LCD. Usually they are sold as a complete unit as it is almost impossible to separate the 2 screens without damage to one or the other. Take a look on the solutions screen to see what others have done or as is the common theme..been unable to do. The front screen/digitiser is attached to the midframe using screws not adhesive, but you will need some way of keeping the LCD secure behind the glass. Again check on the solutions to see what people are doing.. take a look at this guide to see what I mean.iPhone4のディスプレイアセンブリの交換
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The one i've been looking on includes everything including the LCD but as I said the seller said it needed adhesive aswell and my question was, what is this adhesive thingy?
さんによる
コメントを追加
最も参考になった回答
iPhone 4 stock from Apple has two sided adhesive at top and bottom of the iPhone front screen. When you remove the front screen this adhesive remains with the iPhone midframe. So you just install the new front screen and basically reuse the old adhesive. If your front glass is extremely shattered, you may want to remove either or both the top and bottom adhesive. In this case it is not necessary to install new adhesive, just go without. This is how most repairs are done, use what remains, or just go without the adhesive because it is not necessary.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
gronko さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 5,754
