I Cannot charge my iPhone
i cannot charge my iphone though it was being plugged, i tried my friend's charger too, thinking that my charger is a problem, but still cannot
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Your problem could be one of two things, or a combination of both.
First inspect charge port on the bottom of the phone for signs of bent or damage. If all looks OK then clean the pins with Isopropyl Alcohol and a cotton ear bud. If it leaves any cotton behind then remove gently with a set of tweezers.
Second your battery may be totally dead. You can purchase a replacement from iFixit. Link below.
If you need instructions on how to replace it, then follow guide located here.
Good Luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 12,336
1件のコメント
i change battry also same problem, when i plug the charger only singe of apple long time plug on the charge many time also but i can't solve this problem
krishnashrestha44 さんによる
