Upper case from early 2011 in mid 2010
Will the upper case from MacBook Pro early 2011 match to MacBook Pro mid 2010
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yes, these parts are interchangeable: 661-4943, 661-5855, 661-4944, 661-5856
このアンサーは役に立ちましたか?
Yes, just remove them screws, swap the case, it may have a few different markings but they are 100% identical, as long as you have the same size MacBook Pro from 2010 to 2011 then you are golden!
このアンサーは役に立ちましたか?
Does this mean I could use the logic board from a 2011 spec MBP as well?
I realise there may be other modifications needed, but I´m very curious about the feasibility of such an upgrade!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 738
