メインコンテンツにスキップ
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
Why is my screen displaying a black screen and question mark sign?
Why is my MacBook Pro showing black screen with a question mark sign in the middle?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
This usually indicates that it either doesn't see it's internal drive, or doesn't have one installed.
However if it doesn't recognize a present drive, repair is going to be extremely difficult because the ssd is soldered onto the logic board.
Try starting up into recovery by pressing the power button and holding Option-Command-R until a globe appears.
This should allow you to get access to some utilities to check your drive.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for your comment @maxmc. I’ve but it can find the drive
さんによる
コメントを追加
最も参考になった回答
@nmjz5vizxwsgwzm - Time to visit an independent Mac repair shop or visit an Apple Store.
Your system needs deeper repairs.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Well you can try the following methods to fix the issue you are facing:
  1. Press and hold the power button on your Mac for up to 10 seconds, until your Mac turns off.
  2. Use Disk Utility to repair your startup disk.
  3. If Disk Utility found no errors or repaired all errors, reinstall macOS.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for your help @gtip. I have tried this process but it can’t find the disk where I want to install the macOS.
さんによる
コメントを追加
Try this. Shut down your Mac.
Press the start button and IMMEDIATELY press the following 4 keys until you see a startup screen. (You may want to practice your finger positions before you begin because this can be tricky and you have to move fast.)
OPTION + COMMAND + SHIFT + R
You must hold all 4 keys down until the startup screen appears. If a finger slips off you'll need to start over.
You should be presented with an option to restore over the internet. Select your internal drive (if it's shown) and follow the onscreen prompts to reinstall the version of MacOS that came with your computer. You will need a network connection for this to work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kome75y2k さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 95
