メインコンテンツにスキップ
Cowin E7 Bluetooth wireless headphones with deep bass and active noise canceling function. Other versions include Silensys, Tapela.
5回答 すべてを表示
Is it possible to connect Cowin E7 headphones to mac OS 13.3.1
Headphone connection problems
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Yo tengo el mismo problema con una Mac oS Mojave, tuve que comprar un receptor para poderlo usar, pero obvio no es nada cómodo. Leí que al final tienes que actualizar tu sistema operativo, pero los programas que uso no me funcionan si los actualizo.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
What is your Mac system
Are you sure the Bluetooth is active? Are you able to connect other Bluetooth devices?
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
All other bluetooth devices work. The headphones connected to my mac a few updates ago but the bluetooth no longer sees it. Also, I cannot find any update for the headphones. I think I might have to give these headphones away to a friend who uses a windows system. I'll never buy another Corwin anything or any of their related products, but if I can find a way around this I'll tell everybody.
さんによる
@swendas - Let’s not throw the baby out with the bath water quite yet. Give this a try Monitor a Bluetooth Device’s Connection Strength in Mac OS X it’s a bit old but I think it will still work. Give it a try and try a second device.
Can you tell us which system you have as that would help me helping you.
さんによる
Sorry for the delay
Ventura 13.3.1 / all other bluetooth devices work fine. Should I reset the bluetooth?
さんによる
@swendas - Did you review the link I posted? See if that helps
さんによる
コメントを追加
回答を追加する
Swen Das さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 135
