car stalls after running for 30 min.
I've replaced the fuel pump, fuel filter, and fuel pump relay. the only codes I get are for the cat. so I staight piped them both. still stalls after running for 30 min. starts fine after it cools down.
First off after changing all those parts did you reset the ECM? If not the auto still thinks the sensors are bad. Secondly it sound s like you original problem is electrical. Something is getting warm and going into default. Things like the coil and resistors for the ignition will not show on a code reader or self diagnostic reading.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 65
@kijdfp08uw5vqvf what codes did you get?
oldturkey03 さんによる
PO463, PO420,and PO430
mr.skeleton1969 さんによる
