No speaker sounds after screen replacement
I replaced my screen put everything back and can't get my speaker sounds to work what should I do
Hi @farmlife
Which speaker are you referring to, the earpiece speaker or the loudspeaker.
If it is the loudspeaker, check that the daughterboard as seen in Step.22 of the Motorola Edge 5G UW (2022) Screen Replacement guide is properly connected.
If it is the earpiece speaker, see Step.42.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 9
今までの合計 132
