メインコンテンツにスキップ
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418回答 すべてを表示
Keyboard power button works but no trackpad or keys working.
Hi !
I have a 2006 Core Duo 1.83Ghz Macbook with logic board 820-1889-A and the keyboard (top case) is not working correctly.
The power button always works (On or Off with hard shut down) but as soon as the MAC is started or into OS X, the keyboard keys and trackpad are not working at all, no response whatsoever. (impossible to clear PRAM or boot with ALT button on startup)
The MAC is working well with USB mouse and keyboard plugged in.
I've read other topics on this subjects here, but all answers were related to a defective top case.
In my case, i've tried 4 different working top cases but with the same result, only power button is responsive.
I've cleaned the keyboard connector with canned air and they seem perfect, not dirty or bended and the plug is tight, nothing loose.
I'm thinking of a defective logic board, but i know that there are some technical king pins on Ifixit, so might as well try !
Thanks for you time.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Did you try SMC and PRAM resets with the external keyboard ? Another troubleshooting step would be to boot the machine from another volume like your installation disk or an external hard disk and try your top case keyboard while loaded with the external OS
If the problem persists then your logic board is probably faulty.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Hi Lemerise ! I tried resetting SMC and PRAM with external USB keyboard without succes. Also tried to boot with differents MAC OSX hard drive but the problem is still present. So i guess it leads to a faulty logic board ?
Thanks for your help :)
さんによる
コメントを追加
回答を追加する
Thomas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 931
