LCD Screen, which cable does what?
The LCD screen assembly has 3 connectors.
What I want to know is which cable is for what?
One of the cables will be the digitizer, one the LCD DATA and one the Backlight power.
Which is which?
Thanks
この質問は役に立ちましたか?
Which is which?
Thanks
この質問は役に立ちましたか?
Here is a site that has the tear down of the 3Gs: (The link is messed up so you have to type it in by hand. Sorry. ) See image above
http://www.rapidrepair.com/guides/iPhone...
Look at photo with step 2. If you click on the image it shows item #1 is LCD Screen, Item #2 is digitizer. I would guess the last one ( under #1 & # 2) would be your backlight power. (guessing)
The 3G looks to be the same as far as these spots indicate.
Hope this is what you needed.
このアンサーは役に立ちましたか?
Thank you for that!!!
Take a look at the tear down. It should show you what you're looking for.
このアンサーは役に立ちましたか?
No actually it doe snot say which cable is which. Just that they are there and labeled 1 2 and 3.
I want to know which cable is for what.
if the answer has not been given by anybody, I may add tha cable 3 is for ear speaker and sensor that black out screen while listening to a call. Saeed Jabal
このアンサーは役に立ちましたか?
#1 LCD Screen
#2 Digitizer
#3 Ear Speaker
#5 Headphone Jack
#6 Wireless
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 11,226
