メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Backlight filter blown after screen replacement
Someone repaired my old phone and put new screen in it. Afterwords the phone would not display anything and I was told the back light fuse is blown. I really don’t care about this old phone. I just want the pictures off of it. Is it possible to extract the photos off of this iPhone without the screen working? The phone is password-protected and I’ve tried plugging in USB to a computer and use various software with no luck to get the pictures. Thans
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If all that's busted is the backlight filter/circuit, you don't need backlight to get data. As long as the phone powers on, gets image and accepts touch you're usually in business (also need either WiFi or USB to get data). Power up the phone and shine a flashlight at it. Is there any image on screen? If no, this is bigger than just the backlight, you've also got no image. In which case, that's likely to be an issue.
As a note for sake of clarity, the electrical systems which produce image and backlight are different. Which is why your phone can light up, even if there's nothing on screen.
If you cannot see what's on screen to type in a passcode, generally speaking, you can't get data. If I recall correctly, there are forensic tools for some older devices to enable you do enter it with a keyboard rather than on screen. But even that requires a certain type of jailbreak. It's not something the every person who have access to.
Cross my fingers this is just a backlight deal and you'll be all set.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Joe Tom さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 38
