メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kenmore 90 Series は、Kenmore が製造する洗濯機です。
washer doesn't fill with water
My washing machine doesn't fill with water.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch. For the correct part I would need greater detail on your exact machine model.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi,
It could have the switch that does it in a similar situation:
https://youtu.be/Fiv8ckoVAqo
thx,
さんによる
コメントを追加
The pressure switch indicated by Mayer can be tested by disconnecting the tube from the tub and gently blowing into it. As the pressure builds a faint click should be heard from the switch unit ,indicating that the switch contacts have been activated. Another faint click will be heard only when you release the pressure. If the switch clicks before you release the pressure, then the diaphragm inside the unit is faulty.
Another cause could be a faulty solenoid coil on one of the inlet valves. There are usually two, (hot and cold). Isolate the power from the machine and disconnect the two wires from one of the solenoids. With a multimeter set on a low OHM's range, place the prods one on each terminal of the solenoid. If a reading is obtained, the coil is good. If no reading shows, then the coil is open circuit and a new solenoid valve is required. Hope this is helpful.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
+ nice addendum
さんによる
Como llego al tubito, tengo q quitar la tapa que cubre la lavadora por detras?
さんによる
コメントを追加
回答を追加する
steve acuin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 4,811
