メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
A2115 / 2020 / プロセッサ 3.1 GHz 6コア i5、最大 3.8 GHz 8コア i7。2020年8月4日発売。
Mac Won't start up
Hi all,
My Mac was asleep and the next day the power was off, so I tried to restart but nothing. I called apple they walked me through the basic troubleshooting (reset sec etc...) nothing. this was confirmed at the apple store. They suspected the power supply. So I took it home bought a tested used power supply and when it arrived installed it, but still nothing. Looked for the diagnostic leds... found 5 on the lower right hand side of the logic board (not where they are on any photos I saw online, but they look like them. However none are illuminated when connected to power. Where do I go now? I'm not by any means an electronics guy but understand some basic principles and have a multimeter.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
@jre356 that is right. Your iMac has the LED's on the bottom right (marker #1)
画像
Anyhow if LED1 does not light up at all, your iMac does not "know" that power is available. Follow the steps for the diagnostic LED's and let us know what you found out.
IMac 2020 Diagnostic LED
Could be a power supply issue or not connected to the logic board.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Thanks oldturkey3, I have confirmed all of the tests except:
1. verify the connection with the logic board. What's the best way to do this?
2. verify the power supply. What's the best way to do this?
さんによる
@jre356 you would Check the cable connection from the power supply to the logicboard, but if you have not even LED 1 light up, you may not get power to it. Start there. Outlet ok? Power cble ok? You got main power to the power supply? Trace it with your meter. Just remember its full main AC voltage so make sure you treat it with respect so it does not bite you;-) Keep your hands of the board and don‘t touch any of the components. Let the meter probes do the touching. I‘ll check to see if my schematics show where you can check the power supply on the board connector. The craziest thing here is that you do not get LED 1…..
さんによる
Thanks for your help. I used the meter to confirm the ON button works, I disconnected the PS and checked the the input connector which went through the cord to the wall outlet and got 120 V. I checked back with the place I bought the PS from and the said it was tested and was in good working order. I carefully looked over my original PS and saw no indication of component failure or cold solder joints, so not sure it's bad either.
さんによる
@jre356 you checked the connection from your power supply to your logicboard?
さんによる
No, not sure where to check this. I just confirmed that 120V is getting to the PS.
さんによる
1以上のコメントを表示
コメントを追加
Led 4 and 5 is not working on logic bord
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
JRE356 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 66
今までの合計 1,621
