メインコンテンツにスキップ
4輪駆動車やカーゴ付き乗用車の修理マニュアル
20回答 すべてを表示
90 Geo Metro, No spark.
Very strange issue I am having. I was installing a new radio, had it all connected up and had it playing on high volume. I realized I should start the car so the battery could charge. It started right up as usual, but was running poorly. So I turned off the radio (which I assume was drawing alot) and then it idled normally. But I noticed the door open light was not working. So I shut it off and looked and the parking lights/instrument cluster lights were not working. Strange. I put a new fuse in, everything looked good, went to start it, and nothing, it only cranks over. I know there is fuel because I took out spark plug and its soaked with fuel after cranking so much. However there is no spark. How could that all happen from connecting a radio with some nice speakers? Any ideas on what could have happened????
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@carsman248 I wonder if you somehow disconnected the wire to the coil pack (if your Metro has a Tach, start there). Double check your work and see if there is anything off or wrong connected. This is for a '92 but should still work for the '90 as well
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for the diagram, this helped me understand more of how the ECM works. I did have an aftermarket tachometer connected, so I disconnected that just to be safe. I went out there this morning and I wanted to see if the camshaft was turning, because if the timing belt broke I would have these same symptoms. I disconnected the fuel injector so it wouldn't spray more. To my surprise, it started with what fuel was left in the engine probably. I reconnected everything and now it runs, but extremely poorly. the engine is rough and idles terrible. I think the ignition coil may be failing, producing a weak spark? Maybe it was all a coincidence and has nothing to do with my radio.
さんによる
@carsman248 absolutely possible. That is what happens when we wrench around on old Iron. Got to love that :-). Anyhow, happy you got some results. Remember, Repair is War on Entropy!
さんによる
コメントを追加
回答を追加する
Maxwell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 66
