メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Bajaj Discoverは、Bajaj Autoによるオートバイのブランドです。現在、Discover 100 DTS-Si、Discover 125 DTS-i、Discover 125ST、Discover 150 DTS-iの4つのバリエーションがあります。
It can't start
My motor bike is not starting
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 18
13 件のコメント
Geoffrey Ouko what exact model is your motor bike? What have you checked? Do you have fuel? Do you have spark? Did anything happen to it or did this just start all of a sudden?
さんによる
My motor cycle not start
さんによる
Bettry charging
Palag problem
Indicetar chlu
さんによる
البوجية لا تعطي كهرباء قوي
Translation Arabic - English
The spark plug does not give off strong electricity
さんによる
@fgr31679 What make and model bike? What engine size? What year? What have you checked?
Translation
@fgr31679 ما نوع الدراجة وموديلها؟ ما حجم المحرك؟ ما العام؟ ماذا فحصت؟
さんによる
8件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
If your Bajaj Discover motorcycle is not starting, here are a few things you can check:
  1. Check the battery: Make sure the battery is fully charged and that all connections are clean and tight. If the battery is old or weak, it may need to be replaced.
  2. Check the fuel: Make sure there is enough fuel in the tank and that the fuel valve is turned on. If the fuel is old or contaminated, it may need to be drained and replaced.
  3. Check the spark plug: Make sure the spark plug is clean and properly gapped. If it is fouled or damaged, it may need to be replaced.
  4. Check the air filter: Make sure the air filter is clean and not clogged. A dirty air filter can restrict airflow to the engine and cause starting problems.
  5. Check the carburetor: Make sure the carburetor is clean and functioning properly. If it is dirty or clogged, it may need to be cleaned or rebuilt.
  6. Check the ignition system: Make sure the ignition system is working properly. This includes checking the ignition coil, CDI unit, and other components.
If you are not comfortable performing these checks yourself, it may be best to take your motorcycle to a professional mechanic for diagnosis and repair.
このアンサーは役に立ちましたか?
スコア 7
コメントを追加
Try kick start maybe your battery is worn out
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Find your spark plug location. It's may be right and left side of the engine's nearby top side. Their have an adaptor to connect spark plug and that wire. Remove adaptor and directly keep the wire near by engine and kick the vehicle to start. It may cause to electrical shock. So do it carefully. And check any spark is present or not....
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Start with the basics 👍
  • Check battery (most common, does it crank?)
  • Fuel on + not empty
  • Kill switch off
  • Listen: no crank = battery/starter, cranks but no start = fuel/spark issue
If it’s been sitting, fuel or plugs are usually the culprit.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Geoffrey Ouko さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 31
過去 30 日: 168
今までの合計 8,272
