メインコンテンツにスキップ
Apple Watch Series 2は2016年9月7日に発表され、同年9月16日に発売されました。
Snowy/fuzzy screen after ifixit battery replacement
Replaced the battery with ifixit battery kit. I was extra careful throughout the entire repair with absolutely no noticeable damage to anything internal. When the watch gets powered on it shows a snowy/fuzzy picture. Watch still works and seems like touch works. Any answers as to what could be the issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Did you use a solvent trying to take the display off? I’m suspecting that it got between the crystal and the display fogging it
If the display is noisy (snow) that is a bad cable connection
Post a picture so we can get a better idea what you are facing.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I didn't use any solvents. I used ifixit's iopener to open the watch. I'll have to try to check the cables but nothing looks damaged from what I can see. I unfortunately can not take any pictures for a while due to not being around the watch. Thanks for the advice.
さんによる
コメントを追加
最も参考になった回答
Double check all connections are fully seated. Even a mm out can cause issues.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I checked them a few times, feels like they were seated in all the way, I'll have to try again some more. I guess. Thanks
さんによる
@malston make sure the contacts on the ribbons are clean as they're obviously making contact as you have an image. Is there any chance you might of pulled one of the ribbons?
さんによる
コメントを追加
回答を追加する
Marc alston さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 211
