How to remove dust from the speaker?
The sound is bad as if there was object on the membrane
More likely the membrane is torn which over time happens. Using the speaker balance control see if you can ID which speaker is bad it’s also possible both are needed. Here’s the parts Speakers
このアンサーは役に立ちましたか?
Thank you Dan, I'm gonna check the part number on my computer and order it as both speakers are effectively bad.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 49
