メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
Why does my MacBook Pro become incredibly sluggish when the fan's on
I have noticed that my mac has been so sluggish that it is unusable so I went down to Mac OS Snow Leopard (the operating system it shipped with) and it is fine when I do nothing or open one application but whenever I open more than one or even do something like go on the internet, it gets SUPER slow. Also, I have no idea if this has anything to do with it but the wifi and Bluetooth don't work so I'm replacing the airport card soon. Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
There are a few things that could explain things!
The first is if you still have a HDD over time the files get fragmented causing the system to work harder to link up the files fragment to then access it. If you had upgraded to a SSD then you maybe facing lack of space. This causes the SSD controller to shuffle the used space around as the free space blocks are too worn. So the less free space you have the harder the controller needs to work.
In either case the system heats up! Which in turn causes the fan to kick in and slow down your system!
To solve the HDD you’ll want to make a full backup and then use a defragmenter tool to clean up the files. But you do want to clean off as much junk before you do that as the system needs free space to hold some block to then free up space for the file it’s working from. I would run Apples Disk Utility from an external booted up drive to make sure the drive is in good shape. You may want to think about getting a larger drive.
OK, SSDs are a bit different, here the current free blocks are likely well worn, so while cleaning off the junk to free up some space can buy you some time in truth it’s likely time to upgrade to a bigger drive. But you do need to be careful! As many SSDs are fixed speed SATA III (6.0Gb/s) which is to fast for your system! You either need to find fixed speed SATA II (3.0Gb/s) or get one that auto senses the systems I/O speed. So you do need to review the drives spec sheet to figure things out. If it only lists one speed that’s it nothing more (fixed speed) if you see a few speeds listed then it’s auto sense! Here’s an example Samsung 870 EVO SSD note the Interface line which lists all three data rates! FYI - This holds true with HDDs too!
In either case make sure to take the time to clean the dust build up throughout the system focused on the fan blades and the heatsink fin area. So your system can properly cool it’s self and make sure the vents aren’t blocked.
If you still have the Grey disks that came with the system one has the diagnostics see if any error pop with it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brendan Meyer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 24
