メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2693回答 すべてを表示
Why do randomly I lose control of the screen?
Every so often, usually once per day, I will be using my phone and it will, without my touching, swipe around and puch buttons on the keyboard and I will have absolutely no control and it has sent weird messages to my friends. This is the weirdest thing I have seen on a phone. This wasn't a problem before, but I cracked my screen and took it to a repair shop (my parents would let me repair it myself) and when I got it back this glitch started happening. Does anybody know what this is and what I can do? I am very confused.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hello! I've experienced a similar issue like this. You might have tried a few of these things already so you don't have to follow the steps in order. Here's what I would recommend.
1.) While it may seem obvious or stupid, try cleaning the device with a damp, microfiber cloth. If you can't get ahold of one, a paper towel will do. Unplug the device, shut it down, and gently wipe. Based on your issue that likely won't solve it, but it's worth it for the following steps.
2.) If you don't have a screen protector, skip this step. However, if you do, carefully take it off. Repeat step 1 again but you likely won't need to be as particular with it.
3.) If you don't have a hard case, skip this step. Sometimes if you drop a phone in a hard case, the case will bend. This can affect the screen and cause further issues with the responsiveness of the display. Just taking off the case might do.
4.) Force Reset your device. Apple explains it fairly well here. Select whatever iOS version you're running. It can't be iOS 16.
5.) If the problem still continues, I can almost guarantee that your issue was caused by a bad repair job. If the job was rushed, improper seating of the display cable as well as a dozen other issues from faulty repair/parts can cause this. I would personally repair it myself, but if you can't in your current position, I would see if your parents can bring you back to the repair shop or another one available. While most technicians know what they're doing, it's entirely possible for a few negligent ones.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Dimitri Cooper さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 67
