メインコンテンツにスキップ
2017年に発売されたAppleの第3世代スマートウォッチです。オプションで通信機能が付いています。
Apple Watch Series 3: Should I replace my battery?
Hello!
I have an Apple Watch Series 3 that has been in storage for a long time: 3 years. However when I first opened up the box, the watch does not turn on. I have tried charging it, but no luck. No vibrations, or screen life. Nothing works even with a "hard" reset. However whenever I charge it, the watch does get warm. I was wondering if this is a battery issue, or could be a display issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@kneemo based on this "that has been in storage for a long time: 3 years", absolutely. The Apple Watch battery will have to be discharged below it's threshold and will definitely no longer hold a charge. Replace the battery, then re-evaluate. Apple Watch Series 3 バッテリーの交換
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Appreciate the response! Even though it gets warm, does it mean the battery is active though?
さんによる
@kneemo getting warm could just be from your charging circuit trying to charge the battery. It means a charge is applied but will not get stored
さんによる
コメントを追加
回答を追加する
Ronald さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 214
