メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Intellivisionは、1979年にMattel社から発売されたゲームコンソールです。
Help with my Intellivision
I just recently got a Intellivision that was assumed working when I got it for $15 and when I got home to test it, it didn't work. It appears to be sending a signal to the TV, but it wasn't sending a picture. It is supposed to be connected to a VCR but it uses coax in an RCA connector plug.
UPDATE
Replacedthe capacitors and guess what. Nothing. Should I redo the joints? Used the Exact same capacitors.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
6 件のコメント
Did I spell Intellivision correctly?
さんによる
hello, you absolutely spelled it right ;) anyhow, have you tried to connect it through a VCR?
さんによる
Yes, I did connect it to a VCR (who has those anymore? I guess I do.) I got the results that are noted above.
さんによる
I am sure you watched the polarity of the caps when you soldered them in? Any thing else on the PSU that looks out of whack? you said before that the voltage was not matching. what do you get now?
さんによる
The polarity is correct I didn't replace the voltage regulator though, should I replace that?
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
Hello, check this from the service manual:
1. Connect the Master Component to TV, plug in power cord, set the Antenna Switch Box to TV and determine that the set works correctly on broadcast stations.
So, make sure that your switch box is set properly.
UPDATE
Here is a link to an online service manual that can further help you narrow things down.
このアンサーは役に立ちましたか?
スコア 3
14 件のコメント:
Sorry, I didn't know what a switch box was. Do you know where I can get one?
さんによる
This will explain some more http://www.atariage.com/howto/connect.ht... and your best bet would be to try Google to get a switch box. They are still around but hard to find. Not knowing where you are, you might want to try Radio shack as well.
さんによる
Thanks, I found it on AtariAge, and the adaptor is at RadioShack for $4.19. I will buy it tommorow and see how it works and tell you guys. Thanks oldturkey03!
さんによる
Sounds great, good luck to you. Hope it works out and let us know....
さんによる
Unfortunately, it didn't work out. But, I've found the culprit! It's the power supply. It was in the Intellivsion Service Manual. But, does anyone know where I can get one of these. I don't want to have to rebuild it(even though I know soldering pretty well).
さんによる
9件以上のコメントを表示
コメントを追加
回答を追加する
thelectronicnub さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 41
今までの合計 6,380
