メインコンテンツにスキップ
Appleの第5世代スマートウォッチです。オプションでGPS + Cellularモデル機能があります。2019年9月20日発売。
20回答 すべてを表示
Series 5 Apple watch does not turn on
So recently I got a apple watch series 5 from a friend and asked me if I could fix it. The watch just never turned on or showed any sign of charging. I wanted to come here and ask if you guys think it is a battery or a motherboard issue? I mean, Its brand new but has not been charged for 3 years. Last night I plugged it in and still no signs. I also opened it up, and it looks like the battery is not swelling. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Not been charged for 3 years. There's your answer. Battery is goosed.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
We will see. I ordered a battery.
さんによる
Let us know how you get on.
さんによる
Well, It just got here. It started bootlooping, so i thought maybe bad connection. Well, I was right. The connector and battery split in 2. I am so mad right now. I spent $42 and 6 days waiting, and now all of a sudden, when I was trying to unplug it from the battery to plug it in again for a better connection, It just split in 2. It was the battery though, because it had shown nothing with the old battery.
さんによる
@strongbow look above
さんによる
コメントを追加
Did you check the batteries voltage? I would do that to help aim which way.
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
I did, and it did not even register. Also the battery is thinner than a new one.
さんによる
@haw8411 - The battery is no different. Are you saying the original battery has puffed up?
さんによる
@dan No it deflated, It got smaller
さんによる
@haw8411 - That makes little sense, the proper replacement battery should be physically the same size unless the original battery had puffed up which the do when they have gone bad.
Are you sure the replacement is the correct battery? Does the watch work with it?
さんによる
@dan I have not got the replacement battery yet. The original has gotten smaller.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Henry W さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 134
