My watch does not power on, or charge
Watch will not power on anymore, will not charge either
Hi Nazario,
You've got three main places to look if your watch isn't charging; the charger, the charging cord and the battery. Odds are it's one of those three things in most cases.
You'll want to try a different charger and/or a different charging cord to try and eliminate those as a suspect. If it still doesn't work, the next most likely source of a failure to charge would be the battery. Fortunately, iFixit has both a guide to replacing the battery available as well as selling the battery itself, so if that's the problem, they've got you covered. Here's a link to the guide you'll need to do the replacement.
Samsung Galaxy Watch Active2 Battery Replacement - iFixit Repair Guide
You'll need to order the correct battery for your watch; it appears they come in 40 and 44 mm models so pick the one that fits your watch. The guide has links to both where you can purchase them.
このアンサーは役に立ちましたか?
I dont know whether its the battery prob in my smart watch
このアンサーは役に立ちましたか?
Hi Pauline,
What have you tried so far? Have you verified that the charger and/or charging cord work or tried a different one?
過去 24時間: 10
過去 7 日: 34
過去 30 日: 152
今までの合計 3,498
1件のコメント
Have you tried a hard reset?
[deleted] さんによる
