メインコンテンツにスキップ
これらの交換部品ガイドを使って、Samsung Galaxy Watch Active2を修理しましょう。
45回答 すべてを表示
My watch does not power on, or charge
Watch will not power on anymore, will not charge either
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Have you tried a hard reset?
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi Nazario,
You've got three main places to look if your watch isn't charging; the charger, the charging cord and the battery. Odds are it's one of those three things in most cases.
You'll want to try a different charger and/or a different charging cord to try and eliminate those as a suspect. If it still doesn't work, the next most likely source of a failure to charge would be the battery. Fortunately, iFixit has both a guide to replacing the battery available as well as selling the battery itself, so if that's the problem, they've got you covered. Here's a link to the guide you'll need to do the replacement.
Samsung Galaxy Watch Active2 Battery Replacement - iFixit Repair Guide
You'll need to order the correct battery for your watch; it appears they come in 40 and 44 mm models so pick the one that fits your watch. The guide has links to both where you can purchase them.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I dont know whether its the battery prob in my smart watch
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi Pauline,
What have you tried so far? Have you verified that the charger and/or charging cord work or tried a different one?
さんによる
コメントを追加
回答を追加する
Nazario Arteaga さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 42
過去 30 日: 206
今までの合計 2,876
