メインコンテンツにスキップ
モデル番号A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5もしくは3.8 GHz Core i5もしくは4.2 GHz Core i7 Kaby Lakeプロセッサ (ID iMac18,3) / Retina 5Kディスプレイ。システムは類似しているため、修理ガイドについては旧モデルのiMac Intel 27インチ Retina 5Kディスプレイ (Late 2014 & 2015) を参照してください。
294回答 すべてを表示
Internall HDD not showing in HDD list-when restart says uninitialized
Hi there
I really have a big problem, I have an internal storage HDD 3TB which was fine until a couple of days before
At some point when I restarted my imac it disappeared and the disk utility announced me that a hardrive is uninitialized
I tried everything to remount the drive back but no success:
erase
first aid
reinstall OS
different recovery software
etc.
The disk utility list shows an internal drive ST3000DM001 Media 4.14 GB
and in the terminal there is a disk0 showing as a 4.1Gb
(I listed below the content )
I tried to erase / format this ST3000DM001 Media but I get the error:
"unable to write to the last block of the device
operation failed"
I am really at a loss, is there any chance to recover this HDD? I can't take it easily out, as the iMac has the LCD glued to the body :(
see below the available info
Thank you in advance for help!
/dev/disk0 (internal, physical):
#: TYPE NAME SIZE IDENTIFIER
0: *4.1 GB disk0
/dev/disk1 (internal):
0: GUID_partition_scheme 121.3 GB disk1
1: EFI EFI 314.6 MB disk1s1
2: Apple_APFS Container disk2 121.0 GB disk1s2
/dev/disk2 (synthesized):
0: APFS Container Scheme - +121.0 GB disk2
Physical Store disk1s2
1: APFS Volume System 83.0 GB disk2s1
2: APFS Volume Preboot 47.7 MB disk2s2
3: APFS Volume Recovery 1.0 GB disk2s3
4: APFS Volume VM 2.1 GB disk2s4
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Try erasing the the disk using Disk Utility and then select the Security Options box and do a secure erase. This will generally inspect every block and map out the bad ones in the directory and make the disk usable again.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I tried, but it gives me an error
operation failed"
Plus I don’t want to securely erase, will lose the data 🙁
さんによる
コメントを追加
Sadly, you really don’t have much of a choice here. Reformatting the drive is your last hope. It’s possible the drive failed.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I was afraid I would get this answer
I guess I need to take the HDD out and try to reconnect with a different cable and try recover data!?
さんによる
@marinaxx - Just try reformatting using an external drive which is setup as a bootable drive running the same if not newer macOS version. If that fails then open the system up as at that point you more likely need a new drive.
さんによる
@danj
I am running High Sierra
I will make a bootable drive with the latest OS and give it a try
If not I have no choice than to take the drive out and try a different approach
Thank you
さんによる
コメントを追加
回答を追加する
marina さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 113
