メインコンテンツにスキップ
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
561回答 すべてを表示
Charger blew but the board looks OK- how can I be sure?
My macbook was out of battery so i went to charge it.
My charger blew (popped, bang, adapter broke up) so I replaced it with a brand new 85w magsafe charger.
The charger cable connection light wont come on to indicating its charging BUT the laptop screen still comes up with the empty battery/needs charging graphic suggesting the laptop is still ok.
I've opened it up and I can't see anything black or blown up.
Thoughts?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
no light on the magsafe would indicate a dc-in board or mainboard issue
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
@Adam Pritchard - how about installing this gem of an app to look deeper into your batteries health and your charger CoconutBattery post a snapshot of the main window here for us to see.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
@dan it's shut me out again so can't install anything
さんによる
@Adam Pritchard - Then your battery is fully discharged 😞
You’ll need to replace the MacBook Pro 15" Retina (Mid 2012-Early 2013) MagSafe 2 DC-In Board to hopefully get the MagSafe charger to charge your system. Otherwise you’ll need to inspect the logic board for burnt or damaged components. At that point you may need to get your system to someone who has deeper skills.
さんによる
@danj You're a star for the link Dan, I'll give that a try. Thank you
さんによる
コメントを追加
I'd check around the charging connector for blown components like fuses etc.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks both.
I have tried an SMC reset ("Shift-Control-Option on the left-hand side keyboard and the power button simultaneously for 10 seconds")
And the power momentarily returns - enough to see what apps etc I had open. Lasts about 20 seconds then switches off.
Battery % indicator does suggest 20% battery still (tho I think this might be faulty itself)
さんによる
コメントを追加
回答を追加する
Adam Pritchard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 68
