メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1989、EMC 3358。現存モデルに最新プロセッサオプションとキーボード素材に変更が加えられた改良版モデル。カラーオプションはシルバー、スペースグレイ。2019年5月発売。
My touchbar is flashing
How do you stop a touchbar from flashing?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
7 件のコメント
Can you Upload a Video?
さんによる 共有
i think that you may need a replacement, but we need some photos to confirm that you need a replacement or not
さんによる 共有
@djz18 - What Year/Model Number?
さんによる 共有
@beanman56 It's a 2019 13" MacBook Pro 1.4 GHz Quad-Core Intel Core i5 Retina display with 16g memory and 1T hard drive
さんによる 共有
i just updated mine and it stopped.
さんによる 共有
2件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Just spoke with Apple support again and she mentioned a step no other support advisor mentioned...reset the NV RAM. To do this, I held the Option, Command, P and R keys while starting the computer. I held the keys for 20 seconds and the computer did another restart, after which I released the keys. This has stopped the flashing for now. If the flashing restarts again, I'll add to this post. Thanks for your input, if you had responded to this post.
このアンサーは役に立ちましたか?
スコア 8
3 件のコメント:
After using the computer for a couple of hours, the problem with the touch bar is back.
さんによる 共有
Now what? It also worked for a very short time
さんによる 共有
Apple might not endorse this but a strip of gaff tape over the whole thing solves the annoying flashing. Blacked out and gone. Battery life will probably still exceed woeful but, hey! it is a Mac!
さんによる 共有
コメントを追加
In my experience this is a sign that the Touch Bar's display is failing and needs to be replaced. It's not an unusual issue, but it is a bit of a gnarly repair due to the sheer amount of adhesive involved.
This is the process for a 2020 model, which will be quite similar as far as getting the touchbar itself out. Just for point of reference.
このアンサーは役に立ちましたか?
スコア 6
2 件のコメント:
Thanks Alisha. This is very helpful. I don’t think I want to take this type of extensive repair on myself. Do you know a good place to send it for this type of repair, other than apple?
さんによる 共有
@djz18 That's a good question. And I don't blame you for not wanting to undertake it yourself. I would ask friends or family if they have any local recommendations. I don't have any specific suggestions, aside from not Apple since they will not do this repair independent of a full top case replacement, which is quite pricey.
さんによる 共有
コメントを追加
回答を追加する
David zeve さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 47
過去 30 日: 161
今までの合計 22,639
