メインコンテンツにスキップ
Released January 2017, the Sennheiser HD 4.50BTNC headphones are Bluetooth, over the ear headphones.
6回答 すべてを表示
Headphones have stopped charging
I tried to recharge my headphones yesterday and noticed the red light would not come on that indicates they are charging
I tried different usb c cables and plugs. I also cleaned the usb c port on the headphones in case there was a connection issue
The red light will come on for no more than 20 seconds before going out again.
Each usb c cable and plug I try is working with other devices so I'm sure it's not an issue with them.
I've had no problems charging before yesterday and had the headphones for about 2 years
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @mhothi
Try replacing the battery and check if that resolves the problem.
Here's the ifixit Sennheiser HD 4.50 Battery Replacement guide that will help.
Search online for AHB622540N01 battery (supplier example only) to find suppliers that suit you best.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Mark さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 65
今までの合計 388
